Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Here We Go
Old Feb 13, 2008 | 04:58 PM
johnnywarbucks's Avatar
johnnywarbucks
Default Here We Go
okay here is the deal. i just bought a 92 stealth last friday. ive replaced the alternator battery and thermostat. i ran a diagnostic on it and it showed that the crank angle sensor is not sending proper info due to excessive oil leak...which is caused from leakage from the front seals and valve covers. where can i find this sensor and what does it look like so maybe i can clean that off a bit. and it seems like once i fix one problem another pops right up within a day. if possible i would like to get some info on what all i should look at to just keep this car goin for a bit. im not that car savvy so any help will be great.
Old Feb 13, 2008 | 07:19 PM
yevgenievich's Avatar
yevgenievich
Default RE: Here We Go
valve cover gaskets were leaking on mine and i would replace them. As far as sensor, auto part store should have them. I am trying to post a manual for these cars but been having some problems. You probably should do the full 60k tune up(belts, spark plugs,etc...)
