Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
PLEASE HELP!!!!
Old Feb 25, 2008 | 05:27 PM
michap62's Avatar
michap62
Default PLEASE HELP!!!!
Ok i a while back my car ( 92 dodge stealth es ) was over heating and i brought it to a mechanic and they told me it needed a new radiator so me and my dad put a replacment one in, and everything is hooked up normal and right! .... but for some reason my car is still over heating and i have no idea why? it seems like no coolent is circling through the engine! and a lot of air pressure is coming out when i release the air pressure ...... why is my car STILL over heating??
Old Feb 26, 2008 | 10:52 AM
yevgenievich's Avatar
yevgenievich
Default RE: PLEASE HELP!!!!
it is possible that the water pump is going out or bad thermostat. Also check if your fans turn on when the motor is starting to get hot.
Old Mar 6, 2008 | 10:05 PM
invsbl1's Avatar
invsbl1
it could be the temp sensor located at the bottom of the radiator. it controls the cooling fans, my sons failed, the car overheated
[/align]
Old Mar 6, 2008 | 11:45 PM
Blink_Jason's Avatar
Blink_Jason
PSSSSSt ,, if u havent replaced the waterpump yet, do it!
Old Mar 13, 2008 | 12:30 AM
Epyllion's Avatar
Epyllion
1) See if the big fan runs when it start to go hot. Make sure its not intermittent. That means a bad connection by the 4 pin connector from the Fan and to the Fuse box. Also check the fuse.
2) Check the relays. Plug and unplug, make sure you don't brake them.
3) Touch the top radiator hose, if its cool the thermostat is stuck in close position. The bottom hose will be very very hot.
4) If your temperature gage works then your sensor is fine.
I had all these problems. Never had the water pump problem.
