3.0 SOHC Intake Availabilty
I am purchasing a 94 Stealth 5 speed, with 135K, runs good, no smoke.
It has the SOCH 12v 3.0 L V6.
I have heard that this, even though the lessor powerful of the plants, is still quite a good little motor and provides for a quick car.
My question is does K&N or another vendor provide an intake for this particular motor?
I plan to use this car to keep miles off of my 2007 Charger Daytona and Plymouth Duster. Thanks.
RE: 3.0 SOHC Intake Availabilty
I could be wrong but the DOHC intake should work in just fine, if you wanted to keep your maf sensor and such I have the adapter to convert the airbox to a cone filter (or of course pipe it down if you wanted to get colder air from behind the wheel). If you're needing anything let me know via PM or e-mail me.
Both SOHC and DOHC use the same MAF sensor so the K&N would work fine. I used to have a base model Stealth and had no problems using the K&N. You will, however, need an adapter since the stock MAF sensor opening is oval and the K&N filter is round.
Dynamic Racing or 3SX sells 'em with the adapter kit. You can also get 'em cheaper on eBay.
