Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
A few Maintanance Questions
Old Apr 8, 2008 | 12:14 PM
HemiBoss's Avatar
HemiBoss
Default A few Maintanance Questions
What is the easiest way to change plugs and wires on a SOCH 93 Stealth?
Mine runs well, but the idle is sporadic and sometimes idles so rough and low that it dies. At speed, its great.
Also, how difficult is it to replace the oxygen sensors and how many are there? I have a feeling these are a bit aged and need replacing.
Should I just take the car in for the plug and wire change?
Old Apr 9, 2008 | 08:19 AM
dragonvr4's Avatar
dragonvr4
Default RE: A few Maintanance Questions
for the plugs http://www.stealth316.com/2-sparkchange.htm
for the 02's http://www.stealth316.com/2-oxygensensor.htm
they might be diff. i dont know havent got to work on the soch yet. you could also check out 3si.org and see what they have there
Old Apr 9, 2008 | 03:48 PM
yevgenievich's Avatar
yevgenievich
you don't have to take the intake off on SOHC like you do on DOHC. You can reach to the back and remove the spark plugs with a rachet and a socket like you would up front.
Old Apr 9, 2008 | 06:28 PM
dragonvr4's Avatar
dragonvr4
ORIGINAL: yevgenievich
on my vr4 i got it down to 45 min's to do plugs. like i said befoe i havent got a chance to work on a soch
Old May 26, 2008 | 10:21 PM
sneakystealth92's Avatar
sneakystealth92
hemiboss, my stealth has the same problem as yours..same engine, but its a 92..
did changing the plugs work for you or did you have to do something else?
Old May 29, 2008 | 08:50 AM
Mopar.biz's Avatar
Mopar.biz
Before taking out your 02 sensors make sure you have one of these o2 sensor sockets
http://toolsandmore.us/index.asp?Pag...amp;ProdID=238
