Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Need engine help
Old May 11, 2008 | 02:57 PM
zkstealth's Avatar
zkstealth
Default Need engine help
Have loud tick in the engine, seems to be like a lifter or something, changed oil to different weights and revved engine with no luck in changing the tick. any other suggestions?? lash adjusters maybe?? has new timing belt. is 1993 stealth e/s DOHC 3.0 V6 engine
Old May 12, 2008 | 10:03 AM
thestealth's Avatar
thestealth
Default RE: Need engine help
If it's just lifter tick, it's really just an annoyance. You could try something like a seafoam treatment, I've heard that helps. Nothing is a "cure" though except changing the lifters to the 3rd generation style. They have slightly larger oil passages than what you have now. Even then, I've heard they still develope a tick once in a while.
Old May 22, 2008 | 10:15 AM
Mopar.biz's Avatar
Mopar.biz
My friend has a 92 Twin Turbo lots of mods and had a lifter tick put the 3rd gen lifters in problem solved
www.mopar.biz
Old May 29, 2008 | 11:12 AM
zkstealth's Avatar
zkstealth
It seems that maybe this is the timing belt tensioner, could the tensioner cause ticking in the engine? bearing out maybe? It will stop ticking at about 3500 rpms.
zkstealth
Old May 29, 2008 | 11:17 AM
zkstealth's Avatar
zkstealth
zkstealth
