Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
ECU question
Old May 4, 2008 | 08:50 PM
44stealth's Avatar
44stealth
Default ECU question
I hope you guys can give me some advice. It looks like my ecu is fried and can not be rebuild. The car is a 93 rt non turbo. By the year and month I should have a part#190662
but on my ecu is 159963 which is for 92. I checked and so far autozone gave me a quote of 275.seems to be the cheapest. So here are the questions. Are those two interchangable and if so which one I should take? Where would be the best place to buy?
Also somebody told me that if I change the computer I should change the idle speed control motor because those can burn the compters out. I did not have the problem with the idle so far only week sparks on first coil. Thinking back when I used the A/c the engine did not rev up but it was so for more than a year.If you have read my previous posts you know I have a nightmare in the last two months and spent a bunch of money so any advice I do appreciate. My computer was good a month ago at the time the timing belt jumped. Thanks to Bobby who lent his computer they could find that this time it was the ecu
Thanks again
Old May 6, 2008 | 12:01 AM
yevgenievich's Avatar
yevgenievich
Default RE: ECU question
if i recall correctly the 93 was still a first gen so the computer should be interchangable with 92 year. It is possible the computer been replaced before
EDIT: actually i did a little bit of research and it seems like 93+ cars had different sensore setup so that would mean different computer.
I will try and see if i can find a part number in the manual that i got some time tomorrow around midnight
EDIT: i tried to mess around in CAPS program but couldn't finad anything
Old May 6, 2008 | 12:40 PM
thestealth's Avatar
thestealth
Check this site for ECU compatability.
http://johnmonnin.netfirms.com/ECUpartnumbers.html
