Radiator light, and power steering?
My power steering belt is awfuly loose, is there any way to tighten it or is it self adjusting? Also my Radiator light keeps coming on and stays on, what could be wrong? Any help would be greatly appreciated.
You need a long 3/8" extension and I think a 10mm wrench. Loosen the bolt on the tensioner, then using the long extension to tighten the belt. Tighten the 10mm bolt while still applying tension to the extension.
You're either low on antifreeze, you have an air bubble in your coolant system...or you are looking at the wrong light and it is your wiper fluid that is low.
