Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
overheating problem
Old May 15, 2008 | 03:11 PM
mfrankina's Avatar
mfrankina
Default overheating problem
Hi, I am new here and looking for some help. Im in Folsom, CA. We got us a nice auto program at the prison here but the help is a little sketchy and I only get an hour a day out of the hole. Seriously though, the auxillary fans in my 92 Stealth ES don't come onwhen the engine heats up. I changed the thermo and the coolant temp sensor to no avail. Any suggestions? Thanks.
Old May 16, 2008 | 08:48 AM
thestealth's Avatar
thestealth
Default RE: overheating problem
Neither fan kicks on? The one on the driver's side only comes on when the AC is on. Have you hooked the fans up to a power supply to see if they work? Trace the lines back to the relay, make sure it's not bad.
Old May 16, 2008 | 03:47 PM
mfrankina's Avatar
mfrankina
Thanks for the reply! Both fans work as they will come on when the a/c is turned on.
Old May 16, 2008 | 03:54 PM
thestealth's Avatar
thestealth
...but if the AC isn't on, neither fan will ever turn on? They only kick on at a predetermined temperature. Does the car start to overheat after its been running for awhile?
Old May 17, 2008 | 01:09 AM
mfrankina's Avatar
mfrankina
Yeah, a/c off, no fan comes on. The car wont overheat on the freeway, but itdoes in stop and go traffic.
Old May 17, 2008 | 02:12 AM
yevgenievich's Avatar
yevgenievich
i had same problem and strangely adding some coolant helped to fix it. I wonder if ecm could have something to do with it
