Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
rims
Old Jun 29, 2008 | 10:56 AM
sneakystealth92's Avatar
sneakystealth92
Default rims
wat is the widest tire size that you can put on a 92 sohc stealth without having any issues? ive heard it was like 8.5" but im not sure.
also, do the rims that fit a 3000gt fit the stealth too? i know theyre the same car, but i just wanted to make sure they have the same bolt pattern
Old Jun 29, 2008 | 07:26 PM
workinprogress's Avatar
workinprogress
Default RE: rims
8.5 is what comes on the es, that width will fit your base model just fine. back spacing and wheel hight need to be checked though. and the bolt pattern on the 3000gt and stealth are identical.
Old Jun 29, 2008 | 11:38 PM
yevgenievich's Avatar
yevgenievich
Default RE: rims
on stock wheels or using aftermarket wheels? You can go up to 245 wide tire with no problemsif you upgrade your wheels.
Old Jul 3, 2008 | 08:06 PM
sneakystealth92
Default RE: rims
well i have an es so im not concerned about that...
i was thinking about upgrading up to aftermarket 18" rims and im not sure about tires. wat are some cheaper brands that are still decent for rims and tires?
Old Jul 13, 2008 | 04:23 PM
yevgenievich
Default RE: rims
tires for 18" wheels usually are not cheap. I got mine for 17" wheels for about $100 a tire
mine are Riken and work decent 245/45/17
