Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Disable rev limiter
Old Nov 3, 2008 | 05:26 PM
OhioBlueStealth's Avatar
OhioBlueStealth
Default Disable rev limiter
In the stealth is the rev limiter inside the ECM and how do you disable it?
Old Nov 4, 2008 | 03:52 PM
yevgenievich's Avatar
yevgenievich
why are you trying to turn it off? unless you have fully built motor going past rev limiter will just blow the motor. SOHC is set around 6300 and DOHC is around 7300
Old Apr 27, 2009 | 07:02 PM
Magnum47's Avatar
Magnum47
Default Disabling Rev Limiter
How do you disable the Rev Lim. in an '04 Dakota w/ a 4.7L magnum? It cuts out when I hit 99mph haha
