Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
from ticking to knocking
Old Jan 8, 2009 | 11:33 AM
Dizzy772's Avatar
Dizzy772
If you absolutely need a motor, I've got a '91 SOHC for sale with a bit less than 160k on it. I'd say check out 3sx.com though for parts if you're up to building one.
Old Jan 8, 2009 | 12:38 PM
sickstealth1's Avatar
sickstealth1
yea thanks but no thanks the car is a dohc and i have a sohc engine out of a 91 as well for sale
Old Jan 8, 2009 | 02:04 PM
yevgenievich's Avatar
yevgenievich
try flushing oil before getting new motor. Also you can try listening for the noise with the screwdriver. It helps to pinpoint where the noise is coming from.
Old Jan 8, 2009 | 06:36 PM
sickstealth1
what method would u prefer to flush system with?
Old Jan 15, 2009 | 02:58 PM
sickstealth1
i figured out that the problem was a rod bearing. would this problem always damage the crank and rod?thanks for the help
Old Jan 15, 2009 | 03:07 PM
bad venge's Avatar
bad venge
Section Moderator
You will have to tear it down to see if it damaged the crank journals or the rod ...
