Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Need help with door not unlocking
Old Jun 29, 2009 | 12:13 PM
HaloGX's Avatar
HaloGX
Question Need help with door not unlocking
My passenger side door has been finicky for a long time where it didn't always unlock when I turned my car off. Now, it doesn't unlock at all unless you manual push the slide lock on the door. It sounds like its trying to unlock which leads me to believe it may just be a loose connection but can anyone tell me for sure? Also, if its more than just a loose connection, anyone know how much it would run to fix it?
Thanks in advance!
Old Jun 30, 2009 | 09:26 AM
yevgenievich's Avatar
yevgenievich
it might have a bad actuator, you can pull the panel off and see what it's doing. When they start getting wore out it will sound like it's trying to unlock but wouldn't
Old Jun 30, 2009 | 09:50 AM
HaloGX's Avatar
HaloGX
Awesome I'll try that. Thanks.
Old Jul 6, 2009 | 03:24 PM
HaloGX's Avatar
HaloGX
Well I guess it isn't the actuator. I took it in for them to check and the called said it was the latch and a switch. They don't know currently where any switches are but it burned out the latch so even if I got a new latch it wouldn't last long. He wasn't any more specific either about what the switch was.
edit: Turns out its just called the door lock switch, easy enough. Any one have any idea where to find one? I managed to get the latch.
