Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
91 stealth
Old Feb 18, 2010 | 12:45 AM
dipsherry's Avatar
dipsherry
Default 91 stealth
i found a super clean 91 stealth tt for sale dude only wants $750. I already have 2 project but am considering selling the neon to buy the stealth. Only problem is the trans is shot it wont go into any gear i heard car run no crazy sound, clutch felt good. just wondering if u guys could tell me what kind of transmission came in the 91 and if i can use one from any other type of car. thanks
Old Feb 18, 2010 | 08:39 AM
thestealth's Avatar
thestealth
W5MG1 is the part number. You can use the transmission out of a Mitsubishi 3000 VR4. 91's and early 92's had an 18 spline output shaft, the late 92's through 93 had a 25 spline output shaft. The 94 though 96 (99 for vr4's) were 6 speed transmissions, different transmission, transfer case, drive shaft and I believe final rear gear. There are a couple of shops that specialize in rebuilding these transmissions, Kormex in California and JacksTransmissions in Colorado.
Old Feb 19, 2010 | 11:39 PM
woospavega's Avatar
woospavega
You'll pay a minimum of $2300 + transmission swap if you go Kormex, which I would recommend against (took them 3 tries to get it right for my '91 TT).
Make sure everything else really is in good shape. It's hard to check out the car if you can't drive it, even if it looks clean. The forums at www.3si.org are a great resource--much more active than here.
