Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
coil stops working when cars warmed up
Old Dec 30, 2010 | 06:27 AM
93 stealth tt's Avatar
93 stealth tt
Default coil stops working when cars warmed up
i have a dodge stealth twin turbo when i first start the car its running off of all 6 cylinders then when the car gets warmed up about 10 minutes the coil running cylinders 3 and 6 stop firing..if i shut the car off and let it cool down it will do the same thing over is this a sign of a coil goin bad????
Old Dec 31, 2010 | 09:10 PM
highrevr/tflea's Avatar
highrevr/tflea
Ummmm... Try the plug wires? If its distributorless I would think it would not work at all. If its got a distributor I'd check into that.
Old Jan 5, 2011 | 02:19 PM
Girly TT's Avatar
Girly TT
check your ECU. Open it up and check the CAPS for leakage.
Old Jan 6, 2011 | 07:38 PM
93 stealth tt
i fixed the problem i bought new plugs wires and coils and now it all works good so parently it was a bad coil
Old Jan 6, 2011 | 07:39 PM
93 stealth tt
thanx for the help
