Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
JD: I am losing all my MONEY HELP!!!!! OVERHEATING!!!!
Old May 19, 2011 | 07:14 PM
joedanish's Avatar
joedanish
Default JD: I am losing all my MONEY HELP!!!!! OVERHEATING!!!!
Hi, my name is Joe, I own a 94 dodge stealth r/t NA and I changed the thermostat, and it is working correctly because both hoses are warm and pressurized where as only one was before, and that was the previous reason, my car was over heating. well that was only a couple days ago, and my car is overheating again.... there is no leak ( that I can see ), and my fans are on.... but you can hear the anti-freeze or the water boiling inside the engine and the resevoir is getting barely if any taken out of it..... since the thermostat is brand new and installed correctly, my mechanic friend suggested a cooling system flush.... would this be wise? I really wish someone could help, so I have a right idea about how to diagnose this problem..... any thoughts or ideas, would be greatly greatly appreciated!!! thanks again for your time.
Old Jun 21, 2011 | 02:16 AM
Flyman1981's Avatar
Flyman1981
coolant flush would be a good idea. not just the radiator, but the engine as well. How many miles are on your car? 60/120K done? Could be your water pump isn't working as well as it should be.
What does your radiator look like? Lots of the fins missing/flattened out?
What are you doing when it overheats?
