320hp or more out of a es or rt?
i was wondering is it posible to get 320hp out of a non turbo stealth without going bankrupt? ive already got most of my parts picked out to put on my stealth but when all added it the hp only comes to 300. any recomindations?
take some weight out of it...it will have the same effect.
or...
nitrous...you can drop in a nice light shot of 50hp, and it isnt ALL that damaging, when done correctly.
or...
Pretty much what Strat said. 320 fwhp is not easy or cheap to attain staying NA. If you want that much hp, your best bet is forced induction of somekind. TT conversion, supercharged, or nitrous will get you where you want to be.
the way i figure, if youre gone through the work to safely put the car to 300hp, you must have a well put together setup, so a very light shot of the juice will likely be the easiest way to bump a little more out of it.
ORIGINAL: BadStratRT
My sohc engine that i just tested yesterday on the dino delivered 347.4 hp after buying about 5000 dlls on parts
is an NA engine with no bore, i accelerated up to 8000rpm, im gonna place it on my car next week. Of cours ffwhp will be much less than that, this hp are in the flywheel.
