Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
'95 dodge stealth wont shift
Old Feb 6, 2012 | 08:36 PM
dennyjoey14's Avatar
dennyjoey14
New Member
Default '95 dodge stealth wont shift
My stealth will shift from 1st to 2nd fine but wont shift into 3rd, or downshift back to first once in 2nd. the only way to get it to shift back down is to shut off the car and start it again. It has set for 2-3 years in our garage, ran perfect before we parked it.
Old Feb 7, 2012 | 08:46 PM
stokeswill's Avatar
stokeswill
Default Shifting Problems
Sounds to me like it could be your synchronizer for your transmission
Old Feb 8, 2012 | 08:01 AM
Hans_GZP's Avatar
Hans_GZP
I'm guessing auto Trans. You will want to check the fluid condition. It should be bright red. If not, do a fluid and filter change.
Old Feb 12, 2012 | 11:00 PM
dennyjoey14
New Member
yes it is an auto trans, and i checked the fluid and it seamed to be normal, some black smudges that showed up on the rag.
Old Feb 13, 2012 | 08:12 AM
Hans_GZP's Avatar
Hans_GZP
Do a fluid and filter change. Check the fluid level with the car running at operating temperature and the Trans in neutral.
Old Feb 13, 2012 | 09:51 AM
bjr1a's Avatar
bjr1a
I am thinking this vehicle has the F4A33 transmission...If that is the case, it is going to be difficult to diagnose without a scan tool... With a scan tool, I would look at input and output speed data..They fail often on these units....If you cannot find a scan tool there is some ways of at least determining what direction to go, just verify that you do have the F4 trans...
