stealth sputters when the engine is cold
my stealth sputters when the engine is cold and when i try to start it after it sits it takes 4 - 6 seconds to start. but after it starts it will start right up after that as long as i dont let it sit for longer that 10 mins.it just started the sputtering a couple days ago but it has lost prime since i bought it 2 weeks ago.what is going on?
Could be your ECU. Pull that out, and check the capacitors.
Remove the 2 carpet panels on either side of the center console area. 3 bolts hold the golden colored box (just behind where the radio is), and pull it out the driver side foot area. 4 philips head screws hold the cover on. Pull that off (careful not to strip them, they're tight), and check the cylinder looking things for a gooey substance, black/burned board, or if you smell something funky... that is a key indication that your ECU is bad, and you need a new one/rebuid.
If you are not sure what you are looking at, take some high resolution direct head-on pictures of the board, and post them up or email them to me, and I will let you know if it is bad or not.
ECoppola@gmail.com
ECoppola@gmail.com
i checked the capacitors and the board and there are no sighs of leaking or black spots. does it sound like it could be the fuel pump? because i do hear a whistleing or hissing sound that sounds like a turbo coming from the back. only when i get on it and get it up to about 3000 rpm. the car is none turbo.
