Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
91 stealth runs rough
Old May 4, 2012 | 09:04 PM
shanecox's Avatar
shanecox
Unhappy 91 stealth runs rough
my stealth runs rough no codes rough idle no power have replaced the spark plugs,maf, wires check out good. when you unplug maf the car goes into limp mode and runs fine just not above 3000 rpm any help would be apreciated please. fuel injectors ohmed out ok.160 psi compresson in all cylinders.
Old May 4, 2012 | 09:58 PM
shanecox's Avatar
shanecox
also timing is dead on
Old May 7, 2012 | 09:39 AM
Girly TT's Avatar
Girly TT
could be the ecu.
Old May 8, 2012 | 12:26 AM
shanecox's Avatar
shanecox
it shows to be rebuilt but does not look like a good job will replace with parts store one and see if that fixes it will post if it does but cant buy it till end of the month.thanks for replying that helps.
Old May 8, 2012 | 11:49 AM
Girly TT's Avatar
Girly TT
you can't get a parts store one. and if so, they're about $1000+... because they're new OEM... if you can get it.
I have a rebuilt one here, lifetime warranty. $300, + $200 refundable core charge, that is refunded once I receive your rebuildable core ecu of the same part number.
Old May 8, 2012 | 01:13 PM
shanecox's Avatar
shanecox
oriellys can get it for me for same price had them check to make sure and they called and checked and said yes but if they end up not getting it will let you know. the caps have been changed in this one but does not look like good job.just unpluged maf sensor and can drive it to work and back till i get the money for it.thanks will keep you in mind though just incase.
Old May 8, 2012 | 02:28 PM
Girly TT's Avatar
Girly TT
just make sure it's the right part number when you get it. That the bolded numbers (4 digits), match your exactly.
Old May 22, 2012 | 03:30 PM
shanecox's Avatar
shanecox
ok replaced ecu,and tps and still runs rough any other idea's took it to dealer and they do not have connector for stealth but said they thought it was tps so replaced it and same thing any help would be great running out of parts to replace still runs decent with map unpluged and in limp mode.
