Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
fwd can be made awd??
Old Aug 18, 2005 | 05:22 PM
Stealth's Avatar
Stealth
Default fwd can be made awd??
I almost finish my car, is a 1991 first gen stealth, by the outside looks like a tt, but with the original 91 front skirt, 3000gt rear automatic spoiler, and the car is corsa red (ferrari), the interior is fully leather (not original) in black, and i just tested my engine yesterday in a dyno and delivered 347.4 flywheel horse power. i made a hole new reprogramed computer injection system, very light parts for the engine, like titanium valves, forged aluminum conecting rods etc.
with all of that i want my car to be 4wd, can i make it??? with not so much problem and cheap.
p.s. i totally des essembled my car, i sand blasted it, painted it red even by the bottom part and thing by thing, if it was not ok, i got it new or reconstructed it, i started in september last year and im almost finished. up till now i“ve spent mor than 20,000 dollars.
Old Aug 18, 2005 | 05:28 PM
thestealth's Avatar
thestealth
Default RE: fwd can be made awd??
You've spent 20k on your car and now you worried about "cheap." It can be done, but you need many parts to do it. AWD tranny, transfer case, driveshaft, the hole rear subframe assembly, and someone to weld it in place. It is not a simple bolt in job.
I'd like to see pics of this red beast if you have them.
Old Aug 18, 2005 | 05:41 PM
Stealth's Avatar
Stealth
i have pics but i would have to scan them, let me choose some and scan them in a friends house, what i ment, with the las question is if the car floor is the same the gas tank, a friend of mine made an audi a4 to an audi a4 quattro , just for hobby and the car structure is totaly different, he invented so mych stuff
Old Aug 18, 2005 | 05:44 PM
thestealth's Avatar
thestealth
Yes, the gas tank and whatnot is in the same place. There are just a few mounting points that the FWD cars do not have that the AWD subframe mounts too. You would have to weld or fabricate these mounting points.
Old Aug 18, 2005 | 05:49 PM
Stealth's Avatar
Stealth
not big deal,
i will finish my car fwd and later on i will think about it
Old Aug 18, 2005 | 05:50 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
at our mitsubishi site, someone is making a GST into a GSX, and this is the list of what he has so far for the job...
Transmission
Transfer case
Front axles----------------
Drive shaft----------------
Exhaust
Fuel tank and shield-------
Rear subframe
Rear axles-----------------
Rear differential
Swaybar
Rear knuckles--------------
E-brake cables-------------
AWD Flywheel---------------
Recommended AWD Parts (In addition to the above)
AWD fuel tank connectors---------------------------------------------
AWD subframe rear bolts
AWD drive shaft and exhaust brackets (spot welded in the tunnel)-----
Entire AWD rear suspension assembly (all control arms)---------------
Old Aug 18, 2005 | 05:56 PM
Stealth's Avatar
Stealth
im going to wait for that converssion
Old Aug 22, 2005 | 03:37 AM
alan92rttt's Avatar
alan92rttt
This will give you and idea whats involved.
The only person I know of that did it had an entire donor car.
