Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
1991 dodge stealth rt TT won't crank!
Old Aug 11, 2012 | 07:51 PM
Ryankeller's Avatar
Ryankeller
New Member
Unhappy 1991 dodge stealth rt TT won't crank!
Have had the car for almost a year now and absolutely no problems at all! Everything works perfect.. But then the other day after work when i went to start my car it wouldn't start.. I was a bit low on fuel so I thought I could just be empty because I Parked on a hill - but the car wasn't turning over at all .. So I thought maybe the battery? Anyways I was there trying to fix it for 15 mins and randomly it started.. Anyways long story short it worked fine for 2 days after that it then I went to the grocery store RIGHT AFTER putting gas in .... And it won't start at all no matter what I do the car has power! But won't turn over somebody help please? Will it still start if I push start it? (it's a 5speed)
Old Oct 23, 2012 | 09:26 PM
jdeleon's Avatar
jdeleon
I have simaler problems it will crack on push start.
Old Oct 24, 2012 | 01:48 PM
Girly TT's Avatar
Girly TT
Could be your starter, ignition cylinder, low battery/ bad alternator, etc.
Old Oct 25, 2012 | 10:55 PM
jdeleon's Avatar
jdeleon
I found it would crank with starter fluid but not on its own...any suggestion any relays to check before digging for the fuel filter?
Old Oct 27, 2012 | 12:36 PM
Hans_GZP's Avatar
Hans_GZP
If the starter is cranking the engine and it won't start, then push starting it won't work. It sounds like you need to check for fuel and spark first. If you don't have one of those, you aren't making a boom.
