Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
capacitors
Old Dec 5, 2005 | 06:03 PM
rossbrown's Avatar
rossbrown
Default capacitors
One of my capacitors in my ECU is leaking but it got so hot that we can't read the voltage so we can replace it. So could anyone tell us the voltage and the value of the cap, its location number is C102 Right next to the biggest cap
Old Dec 5, 2005 | 07:56 PM
jakster's Avatar
jakster
Default RE: capacitors
Look close to the side and on the corner of the CAP the number willbe printed in small letters look for a 47 uf or a 22uf I will get back to you on this you can find the drawings and pictures at a site which I will also give you.
Old Dec 5, 2005 | 08:01 PM
thestealth's Avatar
thestealth
Scroll down to the bottom of this page.
Old Dec 5, 2005 | 08:03 PM
jakster's Avatar
jakster
OK Go here http://www.stealth316.com/2-ecmremoval.htm I thjink you are looking at the 22 Uf www.3sxperformance has the set of three for $9.95 the solder job is most important both sides need a small dob of solder and the board has to be clean use a scratcher to make sure you are on clean copper foil dont tear the foil. Use solder sucker and solder removal copper strip from Radio (Scrap) Shak to get all the solder off the board or it wil be a botch job and ground your self each time you touch the board if not your static charge may zap the chips.
