Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
alarm problem and engine oil questions
Old Dec 12, 2005 | 02:33 AM
arber's Avatar
arber
Default alarm problem and engine oil questions
I can not just set te alarm( stok security option) with out it going off for no reason if anyone knows anything about this can you please let me know. And i just read that someone mentioned 10w 30 engine oil for the twin turbo models and my mechanic said that this engines recuire 20 w 40 which cant really find so i am using 20w 50 zr1 synt. oil is this right
Old Dec 13, 2005 | 08:40 PM
jakster's Avatar
jakster
Default RE: alarm problem and engine oil questions
This is it. Amsoil is done! The oil exceeded a year in service, with 14,000 miles on the ticker, and no filter change! Well, if the year hadn't ended, we would have had to change the filter now -- it finally reached our insolubles cap, 2,000 miles after Mobil 1. The main thing that stands out on this, our final Amsoil sample, is the ridiculous viscosity. This 5W30 oil has now thickened out to a 15W40 -- argue whether it matters if you like, but we believe engine builders spec an oil for a reason, and this oil is far, far thicker now than intended for the LS1. Switching to our flush Mobil 1 netted a nearly instant 10% improvement in fuel economy, and the engine runs a heckuva lot smoother too. To Amsoil's credit, wear metals remain in check, but we will soon see whether that was really thanks to the oil or just to engine break-in. We'll start posting detailed analysis in the coming weeks.
Old Dec 13, 2005 | 08:45 PM
jakster's Avatar
jakster
The Amsoil did not affect his milage in that test like he has stated some thing else did I am not sure what temprature or what did it. Amsoil still outlasts all the others and your engine will wear less.
