will this work?
RE: will this work?
http://www.3sxperformance.com/exhaust-na.asp so ethir one of these exhuasts will work on the es it says non turbo but i just want to make sure. ill proly get the borla. let me know if they will fit thanx
RE: will this work?
You might want to get a quote from a local exhaust shop. They will be much cheaper than a Borla, and offer similar results. One thing I recommend, about half way between the catalatyc converter and the tail pipes is a small "resonator". Do not remove this, if you do,your exhaust will "drone" at certain RPM levels and not sound good.
