Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
91 Dodge Stealth R,/T TT DOHC starting issue
Old Oct 6, 2020 | 03:04 PM
Blondebomb67's Avatar
Blondebomb67
Default 91 Dodge Stealth R,/T TT DOHC starting issue
Hello everyone,
I have a 91 Dodge Stealth R/T TT DOHC that I did an engine replacement on, first time ever, however there is power but when you turn the key over, there is nothing. We jumped the starter to see if the car would start and it did, but I'm still unable to start from the ignition switch. Any suggestions? PLEASE I just want to GRT it up and running correctly.
Old Oct 6, 2020 | 04:04 PM
Manual or automatic trans?
Old Oct 6, 2020 | 04:14 PM
Blondebomb67
It is a manual transmission
Old Oct 6, 2020 | 04:23 PM
Check the clutch switch. I have no idea where it is on your car though.
Old Oct 6, 2020 | 04:29 PM
Blondebomb67
Ok but why would that have anything to do with it when it's in neutral and starting from the starter being jumped. I will check
Old Oct 7, 2020 | 07:04 AM
Because it's a safety circuit. Car won't start unless you push in the clutch. (otherwise, you could start it in gear, and that could be exciting. )
