Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
engin rev
Old Jan 3, 2006 | 08:25 PM
chiefshoe's Avatar
chiefshoe
Default engin rev
When I start the car (91 SOHC) the rpm's jump to 2000 however as the engine worms up it slowley drops, at a little over the 2 min mark it idels perfect?
New
ECM
Plugs
Wires
Roter
roter cap
fuel filter
oil and filter
set Timing
set TPS
At a loss????
Old Jan 3, 2006 | 08:38 PM
thestealth's Avatar
thestealth
Default RE: engin rev
It looks like the only thing you haven't changed is the IAC/ISC (idle air controller/idle servo controller) but honestly, it sounds like it is running like it should. When you first fire it up, it is supposed to idle faster than normal to get things heated up, then as the engine warms, the idle will return to normal, like what it is doing.
Old Jan 11, 2006 | 03:02 PM
falcon66's Avatar
falcon66
I had a similar issue when I bought my stealth three months ago. My engine would hunt (idle bounce up and down) and settle out at 2K RPM. Fourtunately, I was able to rule out by testing most of the items you replaced. When I had my ECM repaired they told me to check the IAC/ISC. Mine was bad also. It is easy to check. Disconnect the air intake to throttle body to make it easier to get to. Unplug the wiring connector. There are two rows of three blades. Check the resistance between the middle blade and each side one at a time. I believe the resistance should be 30Ω ±2.
