Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
need help
Old Feb 9, 2006 | 12:44 AM
t4dude's Avatar
t4dude
Default need help
i just got done instaling the new alternator and belts. the car hasent been ran in a month. we took it for a drive that lasted about 30 mins and when we pulled in the drive way it died. what would cause that? my dad thinks it needs a tune up. also the battery started out haveing 14 volts when we left and only 12 when we came back why is that? could it be the new cd player?
Old Feb 9, 2006 | 11:23 PM
t4dude's Avatar
t4dude
Default RE: need help
is the stealth's both front tires sapose to spin? and by that i mean are they both powered so if you do a burn out wil it be one tire or 2?
Old Feb 9, 2006 | 11:51 PM
thestealth's Avatar
thestealth
Only one will spin normally. We have what is known as an "open" differential, meaning the side that can spin, will.
As for the voltage drop, chances are, when the car sat for awhile, the battery drained a little. Once you started driving, the alternator was producing extra "power" to charge the battery, once the correct voltage was reached, the voltage dropped to 12V.
As for it dying when you got home...?? Dunno man. Did it start back up?? Is it running OK now?? Let me know.
Old Feb 10, 2006 | 12:09 AM
t4dude's Avatar
t4dude
it starts right up after wards. but once you get it to about 2500 rpms it sputters then dies if you let of the gas. and it idles at about 750rpms.
Old Feb 10, 2006 | 12:30 AM
thestealth's Avatar
thestealth
In situations like this, I always recommend starting with the basics...plugs, wires, filters (fuel and air) and going from there.
