Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Stealth won't crank/start
Old Mar 3, 2006 | 06:18 PM
stealthygorilla's Avatar
stealthygorilla
Default Stealth won't crank/start
93 Dodge stealth non-turbo.
When I try the ignition all accessories turn on and I can hear the fuel pump but the car does nothing. No crank, not even a click. Battery is charged fully.
What would this be?
Starter/Solenoid?
Clutch Safety Switch?
Relay?
Old Mar 3, 2006 | 07:26 PM
thestealth's Avatar
thestealth
Default RE: Stealth won't crank/start
All of the above would be a good place to start...
I would check the wiring to starter/solenoid first, then the clutch switch... Those should be fairly easy visual inspections...you may need a volt meter though for testing the switch.
Old Mar 7, 2006 | 08:20 PM
stealthygorilla
I finally got time to look at it and found that it was the starter solenoid. thanks
Old Mar 7, 2006 | 08:29 PM
thestealth's Avatar
thestealth
Cool, glad to be of assistance.
Old Mar 22, 2006 | 04:13 AM
2stealths2fast's Avatar
2stealths2fast
Hey any idea if this problem could cause the ECU to go bad?
Old Mar 22, 2006 | 12:20 PM
thestealth's Avatar
thestealth
I don't think the starter solenoid would cause an ECU failure...normally the ECU capacitors just go bad over time...with that said, if the capacitors go bad on the ECS (suspension controller) they can cause an ECU malfunction.
