Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
antifreeze leaks from around the crankshaft belt area
Old Mar 15, 2006 | 07:04 AM
DRUNKHORSE's Avatar
DRUNKHORSE
Default antifreeze leaks from around the crankshaft belt area
antifreeze leaks from around the crankshaft belt area. Ive check every angle and tried putting my in hard to reach places but nothing.
1993 Dodge stealth sohc 3liter v6
any help with this is greatly appreciated!!!
also, does anyone have step by step instructions on how to change the water pump?
Old Mar 15, 2006 | 12:33 PM
thestealth's Avatar
thestealth
Default RE: antifreeze leaks from around the crankshaft belt area
If it is leaking from the timing belt side of the engine...I would say that it is the water pump leaking. If you replace the water pump, you should also go ahead and replace the T-belt and all applicable pulleys/tensioners/idlers.
Old Mar 19, 2006 | 02:22 AM
alan92rttt's Avatar
alan92rttt
As the last poster said its probably the water pump.
He neglected to mention one important thing. WHen the pump starts leaking it WILL eventually seize. When this happens it WILL shread the timing belt. Since you have the SOHC you'll just end up with a car that stops in an inconvienant place. Anyone with a DOHC engine will probably need internal engine work it the pump fails.
Old Mar 20, 2006 | 06:22 PM
thestealth's Avatar
thestealth
Good advice Alan...I just assumed when someone's waterpump starts leaking they would replace it.
Old Mar 28, 2006 | 09:39 AM
chiefshoe's Avatar
chiefshoe
http://www.stealth316.com/0-frames.htm
this web sight has the manuals for the repair
