Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
can a stealth do a burn out?
Old Apr 2, 2006 | 04:03 PM
t4dude's Avatar
t4dude
Default can a stealth do a burn out?
to me this sounds like a stupid ? becuase i think a non turbo stealth like the es or rt should be able to do burnouts. but when i still had mine ( in the shop getting tune up and rebuilt tranny) it wouldnt do burn outs. i never tried the ebrake and then gunning it becuase i love my car to much to do that to it. but out of the couple of races i did and the time when i wanted to see what my car could do there wasnt anything close to a burn out if u put the pedel to the floor in my car it dosent go it just sits tehre then it takes off slowly if you just slowy do the pedal and then gun it it takes off quicker. can stealth not do a burn out or is tehre sumthing wrong with my car?
Old Apr 3, 2006 | 01:12 PM
EvilZombieZ's Avatar
EvilZombieZ
Default RE: can a stealth do a burn out?
If you hold the brake and gas at the same time you should be able to do one, just wouldnt be the smartest thing to do for your brakes.
Old Apr 7, 2006 | 02:31 AM
t4dude's Avatar
t4dude
i dont need to do a burn out im just talking aobut the power is the thing not powerfull enouygh to do one by itself?
Old Apr 7, 2006 | 02:54 PM
EvilZombieZ
not by itself. Mine will squeel the tires for a second or two but thats about it. You would probably need rear wheel drive with a good amount of hp to do on with a stealth.
Old Apr 7, 2006 | 03:39 PM
thestealth's Avatar
thestealth
A FWD with a manual will roast them pretty good with stock power...my RT with a slushbox barely spins them and my AWD Stealth...well, it just goes.
Old Apr 24, 2006 | 04:55 AM
Stealth's Avatar
Stealth
my manual sohc with about 370 whp N/A burns out 1st and 2nd 3rd gear a little bit and stil without unsin cluthch triks even though with stock power, in 1st gear without clutching, it burned out
Old May 24, 2006 | 03:57 PM
satanicmechanic's Avatar
satanicmechanic
I have a 94 with a SOHC and a 5 speed and i can smoke the crap outta the tires in 1st and get a pretty good spin going into 2nd if im getting on it pretty hard.
If you got an automatic then you probably cant roast the tires. This is not to say i SHOULD be roasting the tires but i did it sort of on accident because i was trying to take off fast and im used to little 4 cylinder engines and this one just cooked em before i realized how bad i was spinning the tires. you want to use allll your hp then get a manual trans it will be much faster and much more fun to drive.
