Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Curious about engine swap
Old Oct 2, 2006 | 08:00 PM
Willis_93ES's Avatar
Willis_93ES
Default Curious about engine swap
if i got a block from a mitsubishi 3000gt 1992 non turbo. would it bolt right up to my 93 stealth es heads and drop right in, or would i have some issues????????????????????????????????
Old Oct 2, 2006 | 08:44 PM
EvilZombieZ's Avatar
EvilZombieZ
Default RE: Curious about engine swap
same engine for the 91-93 stealth and 3000gt.
Old Oct 2, 2006 | 08:45 PM
thestealth's Avatar
thestealth
Your 93 heads has the crank angle sensor right? If so, it should bolt right up. I think after 93 they went to a different CAS set up.
Old Oct 3, 2006 | 03:10 AM
Willis_93ES
well thats my current plan until things change... i'd love for it to be a lovely slip in. but i have a feeling.... could you possibally check out that sensor thing??
Old Oct 3, 2006 | 01:20 PM
thestealth's Avatar
thestealth
All you have to do is look at your heads on the opposite side of the cam gears. There should be a spot for the CAS on what would be the front head (I think). If that is there, you are good to go, they will drop right on, no problem.
Old Oct 3, 2006 | 01:24 PM
Willis_93ES
and if not? how difficult??
Old Oct 3, 2006 | 01:34 PM
thestealth's Avatar
thestealth
Wait, you are only using the block from the Mitsu and are reusing the head that are currently on your car? They will bolt up no problem.
Old Oct 3, 2006 | 01:37 PM
Willis_93ES
helllllllllllllllllllllll yeah thats all i needed to hear dude thanks. i'm 1 step closer to crusing
Old Oct 3, 2006 | 01:53 PM
Willis_93ES
yeah i wanted to switch out just the block only. i got into a arguement with the mexican dude over the fact that 91-93 is the same... i hope i was correct.
Old Oct 3, 2006 | 02:26 PM
Willis_93ES
cool. thats all i needed to know, i'm 1 step closer so stealth crusin. thanks
