Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
my car has a miss on 3/4 to full throttle
Old Oct 11, 2006 | 09:13 PM
stealthsrt's Avatar
stealthsrt
Default my car has a miss on 3/4 to full throttle
my car has a miss on 3/4 to full throttle a have changed the ecu,o2 sensor,crank angle sensor,ignition control maguol,and tested the throttle positioning sensor and i still have a miss please help.
Old Oct 12, 2006 | 03:06 AM
91Stealth's Avatar
91Stealth
Default RE: my car has a miss on 3/4 to full throttle
could it be your fuel filter or fuel pump? maybe it pumps enough gas at less than 3/4 but then it can't keep up.. or maybe ur filters plugged a little?
Old Oct 12, 2006 | 06:47 PM
mremala's Avatar
mremala
One or more of your plug wires probably has blown a hole in it and when you accelerate, the increase in spark is causing it to miss. VERY COMMON! especially with afermarket plug wires. I have had it happen on (2) Twin Turbos, but not with OEM.
Old Oct 13, 2006 | 12:29 PM
thestealth's Avatar
thestealth
Plugs, wires, plug gap incorrect, dirty air filter.
Old Oct 15, 2006 | 09:07 PM
stealthsrt's Avatar
stealthsrt
just to let you guys know my stealth is a DOHC N/A
Old Jan 22, 2007 | 05:20 PM
shadow72488's Avatar
shadow72488
check the plugs man. I would also check the fuel filter i have a freind that put a ton of money trying to figure out what went wrong with his stealth and it was as simple as fuel filter
