Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
1992 Dodge Stealth tranny
Old Nov 18, 2006 | 07:48 PM
sfortne's Avatar
sfortne
Default 1992 Dodge Stealth tranny
I have a 92 Doge Stealth. The tranny will barely go in drive, but does fine in reverse. Is the tranny shot or maybe a sensor?
Old Nov 19, 2006 | 01:23 AM
EvilZombieZ's Avatar
EvilZombieZ
Default RE: 1992 Dodge Stealth tranny
You may be in 3rd gear and reverse only. If so you would be in limp mode. The most common problem I see with a bunch of people is the capicators leaked on the TCU(Transmission Computer) and screwed it up. Its under the middle of the dash, take off the walls on each side of the driver and passenger seats, and open the TCU and you will be able to see or smell if its fried.
Old Nov 29, 2006 | 11:43 PM
OhioBlueStealth's Avatar
OhioBlueStealth
If you put in a cool air intake you shifter may be getting jamed against it or there may be another obsturction in the way too. Its located right below the air intake. Its a metal shaft sticking up. You may need to get another peson to change the gears to see if the rod it moving freely.
