Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Tranny Problem? hard to put in any gear...
Old Dec 12, 2006 | 08:17 PM
CrimsonRedAshes's Avatar
CrimsonRedAshes
Default Tranny Problem? hard to put in any gear...
I have a 91 Stealth Base model....
when i shift into any gear it feels ruff and resists...sometimes it grinds.....even at a dead stop in first...this happens in all gears except
4th and 5th...i want to check to make shure there is sufficent gear oil...which bolt do i unscrew lol?
ON ANOTHER NOTE....
sometimes on decel i hear a strange noise like a bearing or something coming from the engine bay...like metal on metal i dare say?...but this noise comes and goes regardles of weather the clutch is in or not...
im dieing for some help here...thanks guys
Old Dec 13, 2006 | 02:43 PM
thestealth's Avatar
thestealth
Default RE: Tranny Problem? hard to put in any gear...
I've never looked at a FWD tranny, but hopefully it is similar to the AWD one. The drain plug is on the passenger side, and the fill plug is on the front, about 1/2 way up the tranny. Check and/or replace the fluid. Scroll about halfway down the page for a picture of the filler plug.
As for the engine noise you hear...does it do it idle, get louder as the RPM's rise?
Old Dec 14, 2006 | 01:59 AM
CrimsonRedAshes
it does it with speed, like inbetween certain speeds it can be heard like 5-10.....not with rpm...and it defanitly a tranny noise...not an engine noise...
thanks for the advice on the drain plug..
Old Apr 6, 2007 | 02:58 AM
Jeff7pt62's Avatar
Jeff7pt62
throw-out bearing going bad? I had the same problem in my truck. It make a sort grinding noise occasionally when rpm was just right and I was trying to shift. ONLY when I pressed the clutch. On my Stealth, I simple replaced the whole shooten match.
Old Apr 6, 2007 | 12:20 PM
EvilZombieZ's Avatar
EvilZombieZ
TheStealth is right on the locations of the drain and everything, easy to do just can get a little messy.
Old Apr 6, 2007 | 02:19 PM
thestealth's Avatar
thestealth
...other than being low on fluid, your shift fork could be bent or wearing out.
Normally, a throw-out bearing will clatter when the tranny is in neutral, or when the clutch is depressed.
Old Apr 6, 2007 | 06:25 PM
92stealth's Avatar
92stealth
check your clutch and adjust it. i have a feeling that all these things go bad (syncros and bearings and such) if your clutch is out of adjustment. mine was and all my syncros are starting to go bad.
