Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
HEADLIGHTS
Old Jan 16, 2007 | 12:56 PM
twenty's Avatar
twenty
Default HEADLIGHTS
Hello, my first time here. I have a 1994 Stealth and need some help. My headlights are plastic and are turning frosty, making night vision a little scary. Is there a way of polishing them to bring them back to something that will let light through or do I need new ones. If new are there any breakers that can offer used ones because I'm on the other side of the world and P&P is expensive. I appreciate any help.
Old Jan 16, 2007 | 02:10 PM
thestealth's Avatar
thestealth
Default RE: HEADLIGHTS
They are made from lexan I believe. Are they getting glazed/foggy on the outside? If you, you should be able to use some rubbing compounds and elbow grease to polish them up. I've never done it myself, but I've heard of others doing it.
Old Jan 16, 2007 | 02:20 PM
twenty's Avatar
twenty
Thanks, admin for your swift reply, if good old fashioned elbow grease doesn't work is there a breakers where I could get some cheap used ones?
Old Jan 16, 2007 | 02:45 PM
thestealth's Avatar
thestealth
When you say "breakers" do you mean salvage yard? You'd have to search ebay maybe. They are pretty expensive used and outrageously expensive new.
Old Jan 17, 2007 | 12:23 AM
thestealth's Avatar
thestealth
http://www.moojohn.com/stealth/headlight/
Here is a procedure I found for polishing your headlight covers.
Old Jan 17, 2007 | 12:49 PM
twenty's Avatar
twenty
Again, thankyou for your help, the article made good reading. I do believe that my headlights are the Lexan that you mentioned earlier and the problem isn't the moisture inside it seems to be that the plastic is just rotting to give a frosted look. I'm going to try the elbow grease and look on ebay as advised. Thanks. Any idea what the best rubbing compound might be. I am in Dubai and options are a little limited. Thanks again.
