Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Stick Vs Atuo!
Old Jan 22, 2007 | 05:34 AM
tokex420's Avatar
tokex420
Default Stick Vs Atuo!
Srry if this is a dumb question but whats faster 2 of the same cars, one in manual and the other in automatic, both same cars and specs, which is faster and why if you know?
THX!
Old Jan 22, 2007 | 01:42 PM
thestealth's Avatar
thestealth
Default RE: Stick Vs Atuo!
On stock, equal spec'd cars, the manual is normally quicker in a drag race. Auto tranny's have more parasitic loss than a manual; the torque converter is heavier than a clutch assembly, and the tranny pump sucks away some crank hp as well.
Old Jan 23, 2007 | 05:48 AM
tokex420's Avatar
tokex420
Ok thx for the help!
Also if the stock car had 240HP and the modded car had 240Hp from a stock of 220, and wieghed 100 pounds more, would it still be faster the manual?
Old Jan 23, 2007 | 09:49 AM
92stealth's Avatar
92stealth
stick is better to a curtain point. once you get to a curtain amout of horsepower the a auto is better because you cant shift as fast. for example a grand national, there all autos, if you were to take that engine and put in the same car thats stick it would be slower
Old Jan 23, 2007 | 04:26 PM
skate_or_die2008's Avatar
skate_or_die2008
It really depends on the driver and the shift points to whitch car would win.
Old Jan 23, 2007 | 05:27 PM
falcon66's Avatar
falcon66
Dont forget that power / torque curves and gearing (transmission and axle) have a huge impact on how the car actually performs.
The biggest problem with stock automatic transmissions is the soft, sluggish shifts and usually having only three gears (some newer cars are coming with 5 speed auto's), limiting the range of gearing that can be used. I know the older transmissions (C-4, FMX, TH350, TH400) had shift kits available to improve the shifts. I have not looked to see if anything like that is available for the stealths.
A 5 or 6-speed transmission can better utillize the the engine's peak power curve than only 3 gears. If you can tighten up the shifts in the auto tranny you can offset the gearing advantage a little by less lag time between gears.
Old Jan 23, 2007 | 06:05 PM
User's Avatar
User
Old Jan 23, 2007 | 06:11 PM
Willis_93ES's Avatar
Willis_93ES
I'll always drive manual. for the exact reasons that Falcon said.
the only auto i'll drive is my girlfriend.
thestealth's Avatar
thestealth
ORIGINAL: falcon66
http://www.importperformancetrans.com/ have what you need.
Old Jan 25, 2007 | 04:40 PM
skate_or_die2008
Maunal for me all the way as well!
