Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Turbo and Transmission questions!?!?
Old Feb 11, 2007 | 04:46 PM
onlynj99's Avatar
onlynj99
Default Turbo and Transmission questions!?!?
Hi, I'm new to thisforum. I have a couple questions about a dodge stealth. Where is the turbo located/mounted in the engine (pics would be nice if you could)? Also, I've heard that the stealth's transmissions have a tendency to blow, how is this and is it true? Thanks you, Zach
Old Feb 11, 2007 | 06:13 PM
92stealth's Avatar
92stealth
Default RE: Turbo and Transmission questions!?!?
If your looking at a twin turbo stealth then theres one turbo in the front of theengine and one in the rear, you cant really see them. the trany's dont blow there syncros go bad, witch makes them grind into gear.
Old Feb 12, 2007 | 01:31 PM
thestealth's Avatar
thestealth
What he said. Also, repeated hard launches can be hard on the transmission casing as well.
Old Feb 12, 2007 | 06:11 PM
onlynj99's Avatar
onlynj99
So is there any way for me just to look at an engine and see if it's turbo or not?
Old Feb 12, 2007 | 08:00 PM
92stealth's Avatar
92stealth
the intake says twin turbo. if you look close enough you will be able to see a turbo in the front its just very hard. im sure there are other ways i just dont know the cars that well. are you looking at one right now?
Old Feb 13, 2007 | 03:03 PM
falcon66's Avatar
falcon66
The non-turbo cars have a clear, easy to see air flow path from the intake filter box to the intake manifold. If the air pipe coming into the intake come from somewhere down near the exhaust, chances are it probably has turbo's.
Old Feb 13, 2007 | 04:21 PM
onlynj99's Avatar
onlynj99
ok, I think I got it, one last question though, do the back tires have anything to do with it (size wise)?
Old Feb 13, 2007 | 05:11 PM
falcon66's Avatar
falcon66
I beleive the tire size is the same. The Twin Turbo (TT) cars are all wheel drive, the non-turbo cars are front wheel drive so the driveshaft to the rear wheels should be another tell-tale sign of a TT car. The twin turbo models are the Stealth R/T TT and the 3000GT VR-4 if that helps.
Old Feb 13, 2007 | 05:15 PM
thestealth's Avatar
thestealth
All 4 tires should be the same size, especially on an AWD model. I think Stealth's say something on the rear side windows about them being all wheel drive.
Old Feb 13, 2007 | 11:13 PM
onlynj99's Avatar
onlynj99
ok, I got what your saying. Thank you guys for all the help, Zach
