Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
radiator light on.
Old Mar 7, 2007 | 04:16 PM
94stealthabq's Avatar
94stealthabq
Default radiator light on.
radiator light stays on at all times except when i turn it blinks. coolant full and not over heating. Why else would it still stay on??
Old Mar 7, 2007 | 05:23 PM
falcon66's Avatar
falcon66
Default RE: radiator light on.
This is just a shot inthe dark from what you have told us: The coolant sensor port may be clogged or the sensor fouled. It also appears that there is some confusion about coolant level light and winsheild washer light. Good Luck!
Old Mar 7, 2007 | 06:35 PM
zinger11's Avatar
zinger11
Are you sure you're not looking at the washer fluid indicator light? It looks very similar to the radiator light. Try filling up with washer fluid and see if the light goes out.
Regards,
Kevin
Old Mar 8, 2007 | 10:56 PM
stealth29032's Avatar
stealth29032
i had the same deal rad full and i added some coolant to the overflow bottle and my light stays off now
Old Mar 9, 2007 | 01:38 PM
94stealthabq
it was the washer fluid light. looks like a raidiator. thx its off now
