Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
93 SOHC Crank sensor?
Old Mar 14, 2007 | 07:28 PM
fiddler's Avatar
fiddler
Default 93 SOHC Crank sensor?
Hi My 93 SOHC(mfg Sept. 92) hasan intermittent start problem.
Can anyone tell me where the crank/cam sensor(s) are located on this engine? I've got the timing belt covers off, but can'tseeit. Any help is greatly appreciated.Thanks
Old Mar 14, 2007 | 08:24 PM
thestealth's Avatar
thestealth
Default RE: 93 SOHC Crank sensor?
Is there a crank sensor on the SOHC engine? All the timing should be controlled by the distributer cap.
I am no expert on the SOHC though, so I could be mistaken.
Old Mar 15, 2007 | 01:16 AM
OhioBlueStealth's Avatar
OhioBlueStealth
the crankshaft position sensor is built intothe distributer... but you may have been talking about the camshaft position sensor which is located right under the intake mantifold by the distributer... but you may have to have the timing cover off.
