Dropped!!
Old Apr 8, 2007 | 06:17 PM
Woobang's Avatar
Woobang
Default Dropped!!
Well hey all, Happy Easter!!
I finally got the struts and springs in. KYB Excel-G struts aand Eibach Pro springs. BTW, you will need a camber kit for the rear for the 1.5" lowering. Here is some before and after shots...
Before
After
Old Apr 8, 2007 | 07:31 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Dropped!!
I'm assuming it uses an upper A arm rear ... You can just use spacers (or washers) and longer bolts to space it out to get into specs ... It's usually about 1/4" of spacers ber degree of correction needed... Depending how much needed you might need to get longer bolts
Old Apr 10, 2007 | 08:36 PM
Woobang's Avatar
Woobang
Right you are... but I think I want to get the Eibach on as I've seen others that look like cheap spacers and bolts. Looks like the Eibach one uses a cam method, not sure what the differences are but I sure dont want cheap parts in the suspension.
Heres a look at Eibach's Kit. Specs: Rear +3.0° / -.75° degrees of adjustment.
$70.00
As apposed to these that are 20 bucks more. Specs: Rear -.75°/ +2.0° degrees of adjustment.
$90.00
Old Apr 10, 2007 | 09:25 PM
bad venge's Avatar
bad venge
Section Moderator
I prefer the ingalls ones easier to adjust on car then the eccentric type ones
Old Apr 10, 2007 | 10:08 PM
Woobang's Avatar
Woobang
Do you have a pick or a part# of these Ingalls adjusters?
Old Apr 10, 2007 | 10:30 PM
bad venge's Avatar
bad venge
Section Moderator
http://www.ingallseng.com/parts/35750.htm
Old Apr 10, 2007 | 10:38 PM
Woobang's Avatar
Woobang
Unforuntaly I looked at that site for my application (01 R/T Coupe). Also this part# describes the front alignment kit.
Old Apr 11, 2007 | 12:03 AM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
interesting...devilsreject had his car lowered and while i think that it was the same drop, i dont think that he had camber kits.
Old Apr 11, 2007 | 12:19 AM
bad venge's Avatar
bad venge
Section Moderator
It's truly a crap shoot I've dropped the same cars on same strut/springs and it ranged from no kit ,to a 1.5 kit to a 3 degree kit
Sorry I misread thought the eccentric was front and the bolt eccentric was the rear ... I've gotten ingals for an 01 eclipse (same suspension)
