A604 Transmission Problem? Come here to solve your problem!
Old Apr 11, 2007 | 12:11 PM
kylec4321's Avatar
kylec4321
Default A604 Transmission Problem? Come here to solve your problem!
Pin this please! Save people with transmission problems time and money!
I am in the process of fixing problems with my transmission. A lot of transmission shops will tell you the transmission needs rebuilt when really it doesn't. I found this site with A LOT of information and tips and things to try if you think your transmission is going bad.
Below are a few examples :
Transmission Fluid - DON'T USE DEXTRON! It wears away the clutch, use ATF+3 (or 4)!
Speed Sensor could be the problem
Shift Solenoid
Computer needs retrained
Incorrect filter
Loose electrical work
Those are a few of the most common problems, and 90% of the time your transmission doesn't need rebuilt! Check out the site for yourself for A LOT more information about having a transmission problem..
http://www.allpar.com/fix/trans.html
