99 stratus abs fuse keeps blowing
Old May 24, 2007 | 01:25 PM
blacklabl's Avatar
blacklabl
Default 99 stratus abs fuse keeps blowing
have another problem with my 99 strat..... i had some work done awhile ago on my strat and they changed the ecm....when i got it back the abs light was on...
i just pulled the fuse cove under the hood and discovered the abs fuse was missing so i tried replacing it and it just keeps blowing fuses....now obviously i have a short somewhere.....i'm looking to see if anyone can give me any suggestion's on where to start looking first instead of going on a wild goose chase...any help is
appriciated....thanks
Old May 24, 2007 | 04:32 PM
Dodge Tech's Avatar
Dodge Tech
Default RE: 99 stratus abs fuse keeps blowing
whichs fuse are u replaceing the 40 amp or the 10 amp?
Old May 24, 2007 | 04:38 PM
BloodRed's Avatar
BloodRed
I would have said something when you got the car back. That new computer may be having some problem.
Old May 24, 2007 | 06:33 PM
blacklabl's Avatar
blacklabl
i'm replacing the 20 amp fuse............
Old May 24, 2007 | 08:38 PM
Dodge Tech's Avatar
Dodge Tech
well good and bad news
god news its an easy ckt with no connectors in the middle should be easy to find.
here is what u do unplug your abs computer and see if u still blow the fuse if yes then u have a short in wiring if it does not blow then u have a shorted out abs controler.
If u find the wire to be bad just run a new one from the Fuse box to the abs module.
Old May 24, 2007 | 08:55 PM
Dodge Tech's Avatar
Dodge Tech
here is the diagram
[IMG]local://upfiles/51666/FA99636D2D25425981F5E5BBC44D984E.gif[/IMG]
Old May 24, 2007 | 10:51 PM
blacklabl's Avatar
blacklabl
thanks for the info i'll give that a try.........
dosen't seem to hard to figure out but where is the abs computer located on the car......
thanks again....
