tranny cooler lines
Old Aug 8, 2007 | 10:53 PM
stratusblaze's Avatar
stratusblaze
Default tranny cooler lines
I was wondering if someone could tell me where the tranny cooler lines plug into which hose on the radiator on a 1998 dodge stratus 2.4l. I'm not sure if the top hose on the radiator plugs into the left or right side of the plug mounts on the tranny as well as the bottom hose on the rad vice versa.
Thanks Kyle.
Old Aug 9, 2007 | 09:03 PM
tomthedog's Avatar
tomthedog
Default RE: tranny cooler lines
should be 4 hoses going into the rad. the 2 bigger ones (about 3-4in.) are for the eng coolant. the one comming off the rad cap is also coolant. the tranny cooling lines should be smaller. i have a 2.7L in mine so i don't know how yours look. hope it helps.
