removing oil pan 1997 stratus
Old Aug 10, 2007 | 11:08 AM
chipperdav's Avatar
chipperdav
Default removing oil pan 1997 stratus
Ihit a pot hole and busted my oil pan is this an easy removal process i looked an it appeared that the oil pan would come out without jacking the motor up or anything am i assuming right or wrong. thanks in advance.chipperdav
Old Aug 17, 2007 | 10:30 PM
Dodge Tech's Avatar
Dodge Tech
Default RE: removing oil pan 1997 stratus
same with u what engine size?
Old Aug 20, 2007 | 12:31 PM
chipperdav's Avatar
chipperdav
2.4
Old Sep 28, 2007 | 02:37 PM
littlepunk29's Avatar
littlepunk29
Had mine ('97 2.4) taken off twice. Once on a lift, and once on jackstands by my friend and I. Both times the engine and trans had to be supported and the motor mounts had to be removed so that the crossmember could have some play to drop the oil pan down low enough.
