Oil Change ????
Old Oct 24, 2007 | 09:45 AM
nate_0022's Avatar
nate_0022
Default RE: Oil Change ????
I guess I'm not really sure, I normaly get 300 miles to a full tank of gas.
Old Oct 24, 2007 | 02:23 PM
adio405's Avatar
adio405
Thats one thing I enjoy about my 2.4 is how often I have to fill up, I can usually put around 350 on a tank but on average i get28, 29 mpg, my last tank with a trip down to winona, mn I got just under 400 on my tank, I was happy
Old Oct 24, 2007 | 02:26 PM
nate_0022's Avatar
nate_0022
according to my calculations getting around 300 to a tank i'm getting only 18 mpg WTF!!
Old Oct 24, 2007 | 10:08 PM
adio405's Avatar
adio405
you have to go by how many gallons you put in your tank, cause in only put like 12 or 13 in mine when my light goes off. not 16.9
Old Oct 25, 2007 | 04:59 AM
tacoboy's Avatar
tacoboy
Wal Mart does oil changes? They must not have that up here (in the Northeast) because I've never heard of it. I still change it myself because I will be the one to blame if something goes wrong and not have to deal with some other place or the stealership. Plus I don't mind doing it - I can do it for less than $15.
Also, one caveat, when taking your car to get the oil changed, ask them if they replace the filter as well. Some places with cheap oil change rates do just that - they change your oil and not the filter.
Old Oct 25, 2007 | 09:56 AM
adio405's Avatar
adio405
under 15 dollars what kind of oil do you get, filter?
I don't think i've ever spent under 20
Old Oct 25, 2007 | 10:28 AM
nate_0022's Avatar
nate_0022
I was actually thinking the same thing. I don't think I've ever spent under $20 for a filter and oil.
Old Oct 25, 2007 | 02:34 PM
lngbrding's Avatar
lngbrding
The Valvoline shop does mine. I make then put in the MaxLife semi-syn and filter and it runs $35
Old Oct 29, 2007 | 01:09 AM
Kissmyne's Avatar
Kissmyne
Lol I get like 25 miles to the gallon average.. and thats with me stepping on the throttle a good bit...
I've been testing out synthetics with my car... Right now I've got Castrol in my car, but I think I'll return to either Mobil 1 or Valvoline SynPower... I don't think my car cares for the Castrol too much..... And each time I use a Fram Tough Guard Oil Filter...
Old Nov 3, 2007 | 10:11 AM
sisterteachb's Avatar
sisterteachb
Where ever you go, make sure that when they change your air filter, that they actually unscrew the bolt that tightens the clamp around the air filter's intake tube. I was having mine done at Jiffy Lube. When my boyfriend taught me how to do my own, we found out that they just pulled it off then jammed it back on. So the rubber gasket inside the hose was bent. It wasn't fit together the way it should. So, now I don't go back to Jiffy Lube. I do it myself. It is pretty easy to do! (not that I have to worry about it on my stratus any more) As for walmart - never had a problem there. Always get my tires done there, even after my sister's came off - that's why there is the disclaimer at the bottom to tighten your lug nuts after so many miles.
