02 2.4 noisy when idling
Old Nov 12, 2007 | 04:51 PM
duedja's Avatar
duedja
Default 02 2.4 noisy when idling
Engine seems to make alot of noise when idling lately I didn't notice it when I bought it about a year ago.Any one have any info to share on what might be the cause.? Car has 79000 miles on it.
Old Nov 12, 2007 | 07:13 PM
frankie12's Avatar
frankie12
Default RE: 02 2.4 noisy when idling
Like many Dodge Stratus cars your car probably has a fast idle speed. Mine also does the same thing when it is in idling. How many rpms si your car running at in idle?
Old Nov 12, 2007 | 07:57 PM
nate_0022's Avatar
nate_0022
At idle you car should be at 700 rpms. Have you had your belts checked, especially the timing belt?
Old Nov 17, 2007 | 06:40 PM
duedja's Avatar
duedja
Have not ckecked the timing belt, don't know how.Don't think the idle is off. It runs great,just seems to make rattle ticking sounds maybe its normal I don't know just never noticed it much until lately. Thanks for reply...
Old Dec 2, 2007 | 09:01 AM
pearl01stratcpe's Avatar
pearl01stratcpe
Do you have the sedan or the coupe? The coupes are notorious for having noisy lash adjusters. A 1/3 can of "seafoam" to the crankcase and an oil change with 5w-30 oil should fix it if thats the case.
Old Dec 6, 2007 | 06:36 PM
duedja's Avatar
duedja
It's a coupe. I just recently changed the oil. Where do I get this seafoam?
Old Dec 6, 2007 | 07:18 PM
pearl01stratcpe
Any (most) auto parts stores. Its 16oz (1 pint) and will do wonders. Read the directions on the can. Add it to the oil/ crankcase, and it wouldnt hurt to run it through the brake booster vacuum line and clean the injectors. Its simple and takes just a few minutes.
