01 stratus rear defrost
Old Nov 27, 2007 | 08:18 AM
jackmarks's Avatar
jackmarks
Default 01 stratus rear defrost
the rear defrost is not working. the button and light comes on, but the window does not defrost...any ideals??
Old Nov 27, 2007 | 09:34 AM
nate_0022's Avatar
nate_0022
Default RE: 01 stratus rear defrost
Fuse? but than again I don't think they button would turn on, if the fuse is blown, but i'd still check it anyways.
Old Nov 27, 2007 | 12:41 PM
mechem's Avatar
mechem
Mine seems to take quite a bit to get going. You are giving it some time right.
Old Nov 27, 2007 | 03:50 PM
frankie12's Avatar
frankie12
I would also check your fuse. I have also heard of a wiring problem in some stratus that the cables that defrost the back window lose there connection with the main wire causing it to malfunction, so this may be your problem.
