98 stratus oil light?
hey everyone! i have a 98 stratus 2.5L today the oil light came on. it only comes on when its at idle. oil is good and full. no codes turned up on the diag. does this mean its my oil pump? any suggestions would be appreciated.
thanks!
andrew
thanks!
andrew
ORIGINAL: BadStratRT
bad sending unit.
part number 4608303AB
$13.75
bad sending unit.
$13.75
If my low oil pressure moron light were flickering or illuminating, I would tee in an accurate oil pressure gauge to make sure the problem really is the sending unit. (My other car is a Passat 1.8T, so oil sludge and oil pressure are sensitive issues for me.)
I think that it is the oil sending unit. I had the same problem with my car, with the light flickering at idle and I took it in. They said that I had good oil pressure but I needed a new sending unit. Didn't bother me any cause its under warranty.
