Electrical issue
Old Jan 24, 2008 | 10:39 PM
Qman86's Avatar
Qman86
Default Electrical issue
First off greetings to all members and admin. Now to the point I was installing a aftermarket cd player to my 2004 dodge stratus se and while connecting the wires the radio cut out, my interior lights is out, my power door lock switch don't work, the button to pop the trunk not workin. Can sumone help me with this issue I need to know is that a real big issue or can I fix this myself, please any information is greatly appreciated, thaks in advance
Old Jan 25, 2008 | 02:07 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Electrical issue
Check the fuses you likely shorted out the constant line ....
Old Jan 25, 2008 | 04:17 PM
Qman86's Avatar
Qman86
Default RE: Electrical issue(help)
I may have checked that, I've checked all the fuses in the fuse box and they were all good, but if that's a different fuse where would I find that line? Again thanks in advance
Old Jan 25, 2008 | 07:37 PM
bad venge's Avatar
bad venge
Section Moderator
Check the underhood fuse block too ???
