Steering screeching noise when turned left or right
Old Jan 28, 2008 | 11:47 AM
payneb's Avatar
payneb
Default Steering screeching noise when turned left or right
Hello,
2001 Dodge Stratus -- 103,000 miles
Recently, when I was driving home one night, I noticed a loud screeching noise was coming from when I turned my steering wheel left or right. When arrived at home I played around with it a little bit. If the car is steering straight or at idle, no noise. As soon as I turned the steering wheel hard left or right still a loud screeching (kinda like an old door on a truck that opens) sounds. I took my car in to a mechanic and he said the front-right wheel ball joints were making the noise. He said the newer cars don't come lubricated. For the time being he sprayed some WD-40 and silicone spray to make the noise go away. It went away for about 4 or 5 days. Now the screeching sound is back and loud/embarrasing as ever! The mechanic told me he could replace the ball joints but he told me to wait until it gets warmer, but it's not going to get warmer for a long time here in Northern Illinois! One note: I've had this car last year through Winter and it never did this. SO, it has been through a previous Winter and cold weather.
It just sounds so bad and the sound makes it sound like my ball joint is going to break and I'm trying to avoid any type of accident! Is there anything I can do to make this sound go away or an easy fix? Plus as I mentioned before, it's very embarrasing in parking lots :/
Any suggestions?? Thanks!
Old Feb 20, 2008 | 05:20 PM
payneb's Avatar
payneb
Default RE: Steering screeching noise when turned left or right
I'm new with this forum, does anyone have any suggestions, I'd definitely appreciate it!
Thanks
Old Feb 20, 2008 | 09:22 PM
john1782's Avatar
john1782
Have you checked your power steering fluid level?
Old Feb 21, 2008 | 09:11 AM
payneb's Avatar
payneb
Yes, that was the first thing I checked!
Old Feb 26, 2008 | 12:39 AM
hatsforgrim333's Avatar
hatsforgrim333
ive never heard of it being the ball joints, my ex gf had the same problem with her car and it was a mad embarrrasin noise. i told her it was prob her power steering pump. she took it to a mechanic and thats what he said. they replaced it and no more noise so it could be that.
Old Feb 28, 2008 | 08:10 PM
alexx's Avatar
alexx
the receivortheliquidPower steering has one screen ( filter)you need to clear this
Old Apr 11, 2008 | 02:26 AM
vali's Avatar
vali
I have the same problem. My 1997 Stratus made the most annoying sound until LUBRICATED the Bushings myself. First have someone steer the steering wheel left and right all the way to make sure which side the screeching comes from....FOR me it was my front drivers side.
I jacked the front up and removed the wheel. Check the bushings they usually dry up once they wear out, YOU even might notice that a Bushing might be worn badly..that's ok it still is able to be lubricated. On my 97 stratus I had a worn bushing behind the BRAKE assembly that I lubricated with a SILICONE spray. The other bushing I lubricated was located on the upper ball joint....there is a nut that can be unscrewed so you can spray some SILICONE. Hopefully this helps.
Old Apr 12, 2008 | 08:44 PM
Nick Bain's Avatar
Nick Bain
sounds like the belt is loose.
